You can display current IPv6 BGP+ route information.
  • To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  • The VRF must have an RP trigger of BGP.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select BGP+.
  3. Select the Bgp Route Summary tab to view the BGP route summary information
Bgp Route Summary Field Descriptions
Use the data in the following table to use the Bgp Route Summary tab.
Name
Description
Prefix
Specifies the IP address prefix in the Network Layer Reachability Information (NLRI) field. This is an IP address that contains the prefix with a length specified by IpAddrPrefixLen. Any bits beyond the length specified by IpAddrPrefixLen are set to zero.
PrefixLen
Specifies the length, in bits, of the IP address prefix in the NLRI field.
LocalAddr
The local address of this entry's BGP connection.
RemoteAddr
Specifies the IP address of the peer from which path information was learned.
